Hey Guys, for anyone interested I'm organising a run of UAS pivoting upper control arms. Am aware of alternatives on the market but these being (easily) on car adjustable is a big part of why I want the UAS design on my own car.
I have fourteen buyers on the Z32 forum and eleven spots available if anyone here is keen. $395/pair and I'm taking deposits $197.50 if anybody wants to split payments. I'm mainly active at the AUS300 forum but send me a PM via SAU if you're interested or have any questions and I'll get an email alert so should get back to you pretty quick.
Have copied some more details below
Some info below
Why A Pivoting Front Arm?
  • By design, the front camber arm is required to pivot as it travels through its arc as shown in the video below
  • Without this pivoting centre, the centre of the arm is subjected to torsional load that leads to breakage, worn bearings, and failed adjusters.
About the Pivoting Arms on Offer
  • Improves suspension and steering as it allows unrestricted movement. They are harder wearing than the factory version and other after market control arms.
  • Tig welded, zinc plated, alloy spacers with NSK Bearings
  • Camber Adjustable
  • Suits R32, Z32
  • "Street" Spec to correct negative camber on lowered cars. Total length can be adjusted roughly 170-190mn. Stock length is 178mm.
Version 3 Camber Arms
These will be Version 3 camber arms, which have been improved to address some of the issues experienced with the version 1 arms released in 2009. Key points include pivoting mechanism moved to the center, larger threads, and larger CNC machined body. They are on-car adjustable.
Freight is not included with your order and will be billed with the balance.
Freight to AUS: $20/pair
All prices in $AUD.
On 10/15/2018 at 10:19 AM, R.3.2.G.T.R said:
In
Haven’t heard back since I PM’d you -I’ve got nine spots left so please let me know if you’re still interested
Just an update; I’ve been told the sample will be sent to me tomorrow. Once I’ve done a test for and confirmed everything is 100% the production run will be on.
  • 3 weeks later...
  • 3 weeks later...
PM is always welcome and comes with a convenient email alert at my end :)
I don’t have any shipping info yet so assuming not sent. I’m in pretty regular contact with the factory so as soon as I have something concrete I’ll post in here.
Hey guys, I have been advised that these will leave the factory by end of this week. Not sure how we’ll go with Christmas delivery but either way shouldn’t be long now
Parts are in the air -ETA to me including holiday delays etc is Jan 2. I’ll be in touch re balance and freight once I have the parts.
In the meantime this is quite literally your last chance to order at $395/pair.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
