I was cleaning out the boot of my r32 looking for any tools or supplies that might’ve fell into the  spare tire well. I found these that the previous owner might’ve left there? Lol. Anyways don’t know what they do or are worth but I found their website and apparently they are a Canadian product.
https://www.sau.com.au/forums/topic/475267-ams-tention-rods/
The caster rods control the fore-aft movement of the front lower control arm.  Without them, the lower control arm would be able to move forward and backwards in the wheel well enough to crash into the guard liner, because the bushes at the chassis end of the arm aren't designed to take loads applied in that direction.
The stock caster rods are fixed length.  No adjusting them.  The stock amount of caster in these Nissans is a bit low - only a few degrees.  More (positive) caster provides an increase in the amount of dynamic camber (camber that appears in the wheel angle as the wheel is turned in the steering axis).
The stock caster rods also feature huge rubber/hydrogooshy bushes that provide a metric shit tonne of slop.
These aftermarket caster rods provide the ability to adjust the length to get the amount of caster that you want*.  They also usually use rod end joints in place of squishy bushes, thereby completely eradicating any deflection under load.  In my experience, this is f**king Excellent (TM), as it drastically improves the behaviour of the front end.
* R32s in particular do not like having lots of caster wound into them.  You can wind more into R33s because the upper control arm design is superior.  The more you wind into an R32 the worse the twisting/binding that occurs in the upper arm and shit starts to get real with them, much worse/faster.  Therefore the limit for caster on R32s is probably 6°.  I think I'm running ~5.5°, even with tricky upper arms.
Hmm so these are for thE fronts eh? I would’ve assumed for the rears.
2 minutes ago, GTSBoy said:
Definitely the front.  The equivalents on the rears are called "tension rods" in these cars.  You do not want to f**k about with those.  I have written many words on that subject lately, if you want a read.
And would obviously require an alignment after install yes?  Also with my new coilovers when they come in after I install them even though I’m matching the ore existing ride height do I need a re alignment?
If you set the length of the AMS rods to exactly the length of the stockers (to the centreline of the bolt hole through the front joint) then you won't need an alignment afterwards.  The paranoid would at least get the alignment checked, but the confident would expect the alignment to be unchanged.  Doing so would buy the benefits of reduced slop, but not the potential benefit of winding in a little more caster.  Shortening the rods would best be done AT the wheel aligners, to get the measurement you want.  If you don't know what you want, don't f**k with it.  There is plenty of reading on here to inform you though.
Changing suspension units, even with a small height change, will not require a wheel alignment.  Again, the paranoid would check, the confident would just run with it.
1 hour ago, SeanR32GtSt said:
Is there anything missing from these that would need replacing like a bush inside the endlinks before attempting to install?  And do they actually make a rattling noise?
Now that you mention it....yes, the pair of spacers that goes in the rod end on each one is missing.
Perhaps you should check to see if you have stock arm on the car, or another set of these.
And yes, when rod ends wear, you get metal to metal knocking noises.
I’ll be getting under it in a few days to check.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
