I've always had a slight whine in 4th and 5th in my R33 Gtst 5spd but lately it's turned into a full blown dog box whine under acceleration. It varies a little with throttle and load but for the most part it's always there whilst driving. Is there a recommended transmission rebuilder for these gearboxes to take it to in Melbourne? What sort of parts am I looking at and is it likely to happen again due to power level or is it a wear issue?
https://www.sau.com.au/forums/topic/475382-making-dog-box-sounds/
My old boat would do this, 900ish nm and sticky tyres would chew up the stock boxes real quick.
I even had a good shop (award) rebuild it twice.
The poor old boxes are well past their OEM torque specs when the power goes up.
Flooging the hell out of them doesn't help the situation, but then why make the power and not use it in anger.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
