Hi
For Sale: Nissan Skyline R32 GTS-T M Spec
Registration: Unregistered
Kilometres: 170, 848
Colour: Gun metal grey
Details:
  • Genuine R32 GTR front end
  • Rota grids wheels
  • Coilovers
  • Front mount intercooler
  • Boost controller
  • Pod filter
  • Cat back exhaust
  • Blow off valve - Greddy type RS (quite)
  • New Dayco timing belt
  • New front pulley belts
  • New bearings, crankshaft and camshaft seals
  • New rocket cover gasket
  • New water pump
  • New HD excedy clutch, seals and spigot
  • New diff, gearbox and engine oils
  • New inner and outer tie rods
  • New inner and outer tie rods, front and rear boots
  • New rear brakes (Bendix)
  • New spark plugs (copper)
  • Radiator flushed and new fluid
  • Saas boost gauge
  • 6" speakers, amp, new sub
Interior:
  • No bubbles on dash
  • Clean and Original interior
  • Blue dash lights
Body:
  • Paint faded on drivers side rear quarter
  • Few chips and other minor imperfections
Other inclusions:
  • Original 4 x R32 GTS-T wheels and tyres
  • R32 GTR injectors (Not fitted)
  • R32 GTR  centre triple guages (Not fitted)
  • Blast Pipes (Not fitted)
  • Turbo Timer (Not fitted)
  • 6L Penrite fully synthetic HPR10 10W-50 plus oil filter
Other Details:
  • 1 x genuine key plus 2 copies
  • I have owned this vehicle for 5 years
  • Tow away and will require blue slip for registration. Will pass (Passed when I bought it to transfer to NSW rego).
  • Have all receipts from work completed by me including some receipts from previous owners, some dating back 2003.
  • Recent issue while registered - Does occasionally turn off while driving but while start up again and run. I suspect this is due to fuel filter will need replacing.
  • Garaged and unregistered for the past 3 years.
  • Reason for sale is no longer having the time to work on the car and enjoy driving it.
Price: 12,500
Contact: Please inbox me for any questions and further details.
NOT INTERESTED IN SWAPS, STUPID OFFERS OR TIME WASTERS!
Thank you.
https://www.sau.com.au/forums/topic/475838-for-sale-1992-skyline-r32-gts-t/
Clutch replaced at 170,435 km. (less than 500 km). Receipt to prove.
Other work such as water pump, timing belt, tie rods, brakes, spark plugs all less than 2,000 km old.
Additional interior photos attached.
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
How does the car turn off whilst driving and how often? Will it cut out when coming to a stop or while the car is moving?
If you suspect it's a cheap and easy fix changing the fuel filter why don't you change it over yourself?
  • Like 1
23 hours ago, highwaycruiser said:
Jerking reaction occurs  randomly while driving.
no doubt! ?
Note - i read this as 'action' not reaction.  No i have read it properly it's less funny
Edited by barraspalding
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
