25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 132
Yeah not as fast but the track is way more fun, can drift on most corners and if you do come off, you dont hit tyres which block other parts of the track, but blah blah blah, it is being organised for Kingston park so that is that. If I want one out there, I'll organise one myself instead of cutting in on Mike's effort, sorry dude :)
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-963803
Slow Karts = Boring no matter how big the track...
:werd:
a track with 2 strokes would be best
kingston park I think you have to qualify in the single engine karts to move up to the twin engines, so we would only be driving the singles = a bit limp...
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-964683
Looks like Darlington Park might not be there for too much longer either:
http://www.abc.net.au/goldcoast/stories/s1058706.htm
http://www.msiracing.com.au/
But just rang them up 3382 6000 and they have a pretty standard deal:
For 10+ people for $65 you get:
1x5 Lap warm up
3x8 Lap races
1x Top 8 Sprint Race
And if we want trophies, it is an extra $70, not each, just to cover 1st, 2nd and 3rd trophies.
And they have much faster karts :P
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-964736
1x5 Lap warm up
3x8 Lap races
And they have much faster karts :D
Hey cyrus sounds Good mate if ya can give me a call & we can sort some thing out two heads better than one I always say :rant:
So Who Wants The Darlington Park Race Way Go Karting
Give Me A YES OR NO !!!
Thanks Guys Lets Get Some Thing Set
Cheers Mike:headspin:
List To Date 08/08
Oz
4 Doorz
Knore
Nexus9 (Y 4 D PARK)
Wados + 1 (Y 4 D PARK)
Strutto (Y 4 D PARK)
Melv (Y 4 D PARK)
Twoquik
RB25
Darrinspencer
Charly
Chaos
Ska (Y 4 D PARK)
Jaqule (Y 4 D PARK)
Belgarion (Y 4 D PARK)
Mick51 + 3ppl (ether D Park or Kingston)
Maybe
Growtalski
Lazy-Bastard (Y 4 D PARK)
Evo83 + 5
33 Niz
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-969534
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
