25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 132
ok trying to set this up for the 28th but am having a prob's with Darlington Park, I have sent them emails asking for info & left phone messages with them & still have not gotten back to me starting to piss me off :( so will try & get time tomorrow to give them a call & get it sorted :(
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-978188
Yeah I bought them along to the skidpan day I went to and they had a blast sittin in the back, but they are a bit young to drive karts, 5yrs and 3 yrs :) But dont change dates on account of me, there will always be next time ;)
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-979181
Ok people It is set
Place --> Darlington Park
Date --> 04/09/04
Time --> 3:30pm
Cost --> $65
Maps are up it is exit 38 off the M1 coming down off the ramp go around under the highway & take Stanmore Rd & then travel down Stanmore Rd take Peachy Rd (left Turn) & is a little way along Peachy Rd :)
It is set so come one come all
Cheers Mike
List To Date 17/08
Oz
4 Doorz
Knore
Nexus9 (Y 4 D PARK)
Wados +1 (Y 4 D PARK)
Strutto (Y 4 D PARK)
Melv (Y 4 D PARK)
Twoquik
RB25
Charly
Chaos
Jaqule (Y 4 D PARK)
Mick51 + 3ppl (ether D Park or Kingston)
Slamm
Lazy-Bastard (Y 4 D PARK)
Ska (Y 4 D PARK)
Maybe
Growtalski
Evo83 + 5
33 Niz
Nizmo-Boy
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-982520
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
