25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 132
ok trying to set this up for the 28th but am having a prob's with Darlington Park, I have sent them emails asking for info & left phone messages with them & still have not gotten back to me starting to piss me off :( so will try & get time tomorrow to give them a call & get it sorted :(
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-978188
Yeah I bought them along to the skidpan day I went to and they had a blast sittin in the back, but they are a bit young to drive karts, 5yrs and 3 yrs :) But dont change dates on account of me, there will always be next time ;)
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-979181
Ok people It is set
Place --> Darlington Park
Date --> 04/09/04
Time --> 3:30pm
Cost --> $65
Maps are up it is exit 38 off the M1 coming down off the ramp go around under the highway & take Stanmore Rd & then travel down Stanmore Rd take Peachy Rd (left Turn) & is a little way along Peachy Rd :)
It is set so come one come all
Cheers Mike
List To Date 17/08
Oz
4 Doorz
Knore
Nexus9 (Y 4 D PARK)
Wados +1 (Y 4 D PARK)
Strutto (Y 4 D PARK)
Melv (Y 4 D PARK)
Twoquik
RB25
Charly
Chaos
Jaqule (Y 4 D PARK)
Mick51 + 3ppl (ether D Park or Kingston)
Slamm
Lazy-Bastard (Y 4 D PARK)
Ska (Y 4 D PARK)
Maybe
Growtalski
Evo83 + 5
33 Niz
Nizmo-Boy
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-982520
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
