$200 firm.
Nothing wrong with it at all, just a bit scratched and discoloured. Used for less than 7000km. Has an O2 sensor bung. Excellent cat that provides the best flow from a large body and 100 cell.
"304 GRADE STAINLESS STEEL
3" INLET/OUTLET
5" BODY 100CPSI
DIRECT BOLT ON
TO SUIT - NISSAN R34 GT-T Coupe (not really sure what else it fits)
VENOM EXHAUST WORKS would like to introduce their bolt on range of High Flow Cats to suit Nissan Skyline R34 GT-Ts. This Bolt-on cat is our new 500 Series unit which comprises of a 5" Body Cat (3" in/out) with a 100CPSI substrate for uncompromised flow. It will bolt up to the R34 GT-T if the cat is in the factory position with 3" Pipework.
The High Flow Cat on this piece is also our latest design where the metallic substrate, as well as being welded to the casing, is also welded along the inner edges for extra strength, helping to prevent core substrate shift. The piece is also made from 304 Grade Stainless for long lasting durability.
Turbocharged cars are more sensitive to exhaust restrictions than their NA counterparts, so by replacing the factory catalytic converter on your Nissan with a high flow unit, the result will be an increase in power, increased boost pressure and response, as well as giving your car the ability to build more boost earlier in the rev range. The standard catalytic converter is only a 400CPSI design and features a ceramic substrate. Not only can it not flow the necessary amount to support higher power at efficient boost levels, the ceramic substrate is much weaker in design than a metal core cat.
The 5" Body Cat listed here supports more flow and can withstand higher operating temperatures than the smaller 4.25" 400 Series Version, making it ideal for vehicles with more extensive modifications"
Located SE VIC
0433543344
Edited by TurboDoseBro
  • 3 weeks later...
  • 3 months later...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
