3 piece forged NOX wheels 20x10.5 +12 off my R34 GTR gloss black dish satin black centre falken tyres front tyres are almost new ,rears are fairly new ,stud patterns 5x114.3 $3000
R34 GTR mechanical non vspec diff 3:545 ratio with nismo 1.5 way diff centre assembled by award diff $2999
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit $1999 hasnt been used since fitted
Brand new high octane racing billet rear driveshaft inserts $1000 or if someone wants a full set $2000
Rare R34 gtr non vspec crown wheel and pinion 3:545 ratio ready for a aftermarket diff centre will fit into any non vspec diff housing will throw in other spares everything that in the container are all 34 non vspec pieces $750
Brand new Plazmaman 85mm throttle body with hdi clamp welded on with s15 throttle cable to suit $750
Brand new Precision 66mm wastegate brand new in box $665
R34 gtr back half of tailshaft $350
R32 gtr front half of tailshaft $250
R34 gtr power steering hardlines with brand
new pressure switch $250
R32/33 gtr drivers side front shaft suits reco $200
2x Geniune BBS LM F1 black and gold centre caps $150
R34 gtr factory wheel nuts full set 20 pieces $50
R32 gtr gearbox crossmember $50
R34 gtr/gtt boot brake light $50
Rb26 bottom timing cover $50
Rb26 backing plate $50IMG_8403.jpgIMG_8404.jpgIMG_8405.jpgIMG_8425.jpgIMG_8436.jpgIMG_8419.jpgIMG_8418.jpgIMG_8420.jpgIMG_8424.jpgIMG_8430.jpgIMG_8412.jpg
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit hasnt been used since fitted $1750 or will swap for r32 33 34 gtr rear brembo kit calipers pads rotors and brake lines with $1000 my way
Brand new Precision 66mm wastegate in the box $650
Brand new Plazmaman 85mm throttle body with hdi clamp welded on ,throttle cable included $600
R34 gtr non vspec crown wheel and pinion 3:545 ratio it will fit into any non vspec diff housing $550 will throw in a housing so all you need is a aftermarket diff centre and off you go
R34 gtr back half of tailshaft $300
R32 gtr front half of tailshaft $200
new pressure switch $200
R32/33 gtr drivers side front shaft suits reco $150
2x Geniune BBS LM F1 black and gold bbs logo centre caps $120
Rb26 girdle $50
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/#findComment-7904902
  • 1 month later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
