I'm looking to purchase a Skyline that I can race in the US in multiple racing series. The only Skylines I can find in the states ae converted to US- Street legal and can cost as much as $100,000 US, or 142,267 AUD. Since my purposes are to use the car as a pure track car it does not need to be street legal in the US, so I'm looking for something much, much less. So I'm looking for a 93 or above Skyline GTR (no GTS) AWD, Turbo (can be twin), engine and drive train must be in Good condition, like to have minor to no body damage, but interior will be gutted for safety equipment so it can be in any condition, I'd like to have an R34 but an R33 or R32 will do. I will take car of shipping it to the US, I may ask that you arrange for it to get to the transport (ship or plane). If you have any questions or you have what I'm looking for you can PM me or post it here.
Edit: Sorry forgot to mention it must be a Manual transmision.
https://www.sau.com.au/forums/topic/47692-wtb-93-skyline-gtr-r32-r33-r34/
go direct to japan , you can buy a stock r32 from 700,000 yen , r33 from 1.2 million and r34 from around 3 mil + fob in japan ( 90,000 yen ) + shipping costs ( about $ 1000 us )
Horse, have a look at the kind of prices the 32,33,and 34 gtrs are going for in Japan. Dont worry about all the calculations to get it into Australia, find out what taxes etc. apply to you for importing the car into USA.
www.j-spec.com.au
eg. http://www.j-spec.com.au/list/index.php?ID=0804
www.prestigemotorsport.com
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
