Alpha & omega 350mm brembo rear brake kit with evo 8 rear brembo calipers powdercoated white but will powdercoat any colour you like
Brand new billet alpha & omega mounting brackets
Brand new dba t3 4000 rotors
Brand new winmax w3 pads
Brand new brembo brake seals
Brand new braided brake lines
$1750
Or if you want to swap your gtr rear brembos with a $1000 my way we can do that
Brand new precision 66mm wastegate $650
Rare R34 gtr non vspec crown wheel and pinion 3:545 ratio it will fit into any non vspec diff housing ,will throw in a diff housing so all you need is a aftermarket diff centre and off you go $500
R34 gtr back half of tailshaft $300
R32 gtr front half of tailshaft $200
R34 gtr power steering hardlines with brand
new pressure switch $200
R34 gtr bottom grille mesh $150
R32/33 gtr drivers side front shaft suits reco
$150
2x Geniune BBS LM F1 black and gold bbs logo centre caps $100
R32 gtr gearbox crossmember $50
R34 gtr/gtt boot brake light $50
Rb26 backing plate $50
Rb26 girdle $50IMG_8804.jpgIMG_8793.jpgIMG_8794.jpgIMG_8796.jpgIMG_8797.jpgIMG_8800.jpgIMG_8799.jpgIMG_8803.jpg
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
