sorry i tell a lie, the r33 wasnt my *FIRST* ride ever in a skyline, my *FIRST* ever ride in a skyline was in my dads r31 company car. i was too young to remember anything bout how it went, but my parents always had good things to say about it so i guess it was rather quick. they were always suprised how it beat their worked v8 holden hk brougham off the line. The r33 had the greatest effect on me though, it was all i talked bout for days after my first ride in it :cheers:
First ride was back in 2001 in a R33 GTSt, big apexi front mount, high flowed turbo, was awesome and pulled pretty hard... the owner wrote it off 2 weeks later around a tree.
Second ride was in 2003 in a R32 GTR with N1 spec turbos, making a considerable amount of power. This thing hauled arse, and I bought one a few months later.
first dealings with turbo import skylines...
R30 sedan with L20ET & possibly the most retarded auto gearbox I've ever had the displeasure of using. Slowest car I've EVER been in up to 60km/h yet quite fast & responsive between 100 & 140km/h. weird...
with R32 & 33 sedans I remember wondering 'where's my low down response'. fortunately the top end kicks in & it seems like much less of a problem!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
