Hey guys,
The alternator on my RB20e in my A31 took a crap on me.  My buddy has a spare RB20DET one.  Will it swap over or are we going to end up wasting a few hours to try it to see.  Either way, I'll end up taking the old one out to rebuild it if necessary but I'd rather spend the few hours getting it down to a place to rebuild it rather than finding out the hard way the RB20DET one doesn't fit.
Thanks!
Dustin
Edited by dj8684
https://www.sau.com.au/forums/topic/477394-will-rb20det-alternator-fit-rb20e/
I can't see any reason why not. The brackets all bolt to the block, no involvement with the head, and the block is the same. The drive belt arrangements on the front should all be same same. Nissan didn't use different shit between different chassis if they could avoid it, let alone on the same basic engine in the same car.
  • Like 1
Nice!  Well, that certainly gives some encouragement! We're gonna test it out today and I'll share my progress either way.  I know that the alternators have different part numbers from when I looked them up but then again, a lot of parts do even though they're interchangeable.  Let's see what happens!
So... I can CONFIRM that the RB25DET S2 alternator fits on the RB20e SOHC motor.  Everything was plug and play.  The RB25 one is a bit beefier which is nice so it should provide a little more juice.  The only thing I had to do was buy a slightly larger belt as the one for the RB20e was just a hair too small.
  • Like 2
Good work reporting results, threads with no outcome make baby jesus sad
  • Like 2
  • Haha 1
hahaha true dat.  I'm actually starting to document all the stuff little by little on my YouTube channel.  I'm gonna start a build thread on here and post the links as a I go.  Sadly, I couldn't film the process on this one because I had to do it in my dark parking garage BUT now that it runs, I can actually take it out in the Sun and start the builds from there.  Here's the build intro vid if you wanna check it out:
  • 1 year later...
Hey there,bringing back this forum
I have a c34 laurel with a RB20e and the alternator crapped out a couple weeks back. I managed to score a reconditioned RB25DET alternator out of an R33 which fit directly in etc, However it somehow looks misaligned to me. This may have been because i swapped over the RB20e alternator pulley onto the RB25DET alternator.
@dj8684 Did you just install the RB25DET alternator and RB25DET pulley and just get a bigger belt? Cheers.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
