Everyone please check their PMs in about five minutes.
I will be placing the order on my subbie this Friday before I got back to Noumea for another week.
Means I should have the parts back to me within a week, then getting the bending done the first couple of days the following week.
Payments now due.
  • Replies 175
Okay gents, heres the low down.
I'm going to have the first batch of Nismo guides made up, then I'm going to butcher the 'work-shop hack' guide I have here and make sure 100% that it fits the standard bar. I wouldn't want to make a bunch up and have to angle grind them to fit, because that would be crappy!
That means that those with standard (and aftermarket bars) will have to wait a touch longer, but it means you will get a perfect guide, not a 'suck it and see' guide.
Bear with me, as the wait will be worth it.
I promise to have them done as quick as I can.
BASS OUT
Could you please photograph the front bar for me.
Also the bonnet where the radiator guide will be going.
ASAP please, as I need to order the panels at the latest tomorrow.
For all others, the Nismo bars will be bend up today, and ready for delivery any time.
I will photograph it on my car when its done.
I'm then flattening the 'workshop hack' version to make sure my calculations are correct for the standard and aftermarket bars.
I'll keep you posted later today.
BASS OUT
Shipping wont be too much.
I'll be putting on the work account which means pretty low prices.
I will be wrapping them quite severely in cardboard and bubble wrap to make sure they dont get bent.
I'll get quotes from TNT and let you know.
BASS OUT
Erik.
I thnk the best thing I can do with your guide is to make you one just like (GTTR34) who has an URAS front bar.
From what I have seen of the fronts bars (Nismo, Stock, URAS) is that the front of the aftermoarket bars is very similar to the stock bar. The edge of the URAS bar needs a little section removed which by the photos on your dar-domain website looks like yours will too.
The stock bar comes forward from the radiator support bar, where the nismo bar actually goes above that bar.
I cannot gaurantee 100% that it will be 100% perfect, but I think it will be damn close.
I will be cutting the rest of the panels late this week.
I wil recieve the finished guides for the nismo bars today, and I will photograph them when I have them.
That's when I'm going to butcher the old panel to make sure all will be good with the profiles I've already devised.
Almost done ppls.
PS. My next group buy will be a replacement pipe (made from alloy) for the AFM to turbo snout. I've been wanting to do this for ages and haven't had the time. I'm thinking of doing one also for the R33 and R32. Kit will included all clamps, silicone and ally welded pipe.
So, any interested?
BASS OUT
This afternoon.
Or tomorrow morning.
See the above post though. I think the URAS guide (which is identical to the stock bar, just with a little snip from the edges) will be fine on the C-West bars.
BASS OUT
So, any interested?
BASS OUT
Any interest?
I was asking about these back in Feb 2003! Check thread:
AFM to Turbo air intake piping one of my first threads :D
YES I am interested, there may be some useful replies in that thread BASS, particularly regarding having flexible hose / joins at each end!
Let me know how she goes. Also, how are the standard bar radiator guides coming along?
:rofl:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
