SAU Dyno Day At Unique Autosports - Saturday August 21st
  • Replies 183
Well, if you'd be happy to tolerate a queenslander who just happens to be in Sydney that weekend, I'll be in too. :D
My car isn't that far beyond stock, but will be good to meet people, put faces to names, etc.
Edit: Erk, forgot to mention I'm not actually a club member, just a forum member. Guess I'll just have to see how my luck is on the day.
Im going along to spectate, silver gtst asked me to today... I want to meet some of you guys.. but then again is that a good or bad thing :uhh:
Tosh is going, he will "look after you" :)
Will be good to meet you Taiya, is this the first official SAU event you will have attended?
Oh and B-Man, another car confirmed today thats going to give you a serious run for your money. He isnt a forum regular either so im not going to give away and secrets :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
