Hi guys have been upgrading my r33 gtr I have purchased a Hks fuel rail but I am using 800cc sard injectors.Everything seemed to be lined up fine except the plug on the back of the injector when I tried to click it in seems as the fuel rail is to close has anyone encountered this issue? Do I need injector extenders?
Oh, my, god. Really ? What injectors were you running before as they are not the standard injector bosch type EV1 style connectors. You are trying put the connector on upside down for a start as the push release goes the other way, but it still won't fit - why ? I'll tell you.
The Denso / Sard 800cc low impedance injector uses the Denso "low" guide connector and your loom is fitted with the Denso "high" guide connectors (which are on the Denso / SARD low impedance 1000cc injector by the way).
You need the Denso low guide connector or butcher the injector side guides (cut off) for those 800cc ones.
Or just get rid of that and get some 980cc + Bosch EV14 injectors, then you can delete your resistor pack.
3 minutes ago, BK said:
Oh, my, god. Really ? What injectors were you running before as they are not the standard injector bosch type EV1 style connectors. You are trying put the connector on upside down for a start, but it still won't fit - why ?
You need the Denso low guide connector or butcher the side guides (cut off) for those 800cc ones.
Or just get rid of that and get some Bosch EV14 injectors, then you can delete your resistor pack.
I ended up trimming the front clip part that  was hitting the fuel rail they fit on fine now
Don't need to trim anything with the right connectors as those connectors are either upside down when you were trying to fit, or they were put onto your wiring upside down mate. You are still using a high guide connector on a low guide injector, hence being upside down (wrong).
Really ? From New ? That is strange. Ok so you've cut the stock connectors off yourself and done this. You get what I'm saying right ? Why did you not go the much superior Bosch EV14 injector ? The Denso / Sard injectors are not cheap new for such an old design.
Right connector from EFI hardware in Vic.
https://www.efihardware.com/products/1512/injector-plug-Japanese-low-guide
10 minutes ago, BK said:
Really ? From New ? That is strange. Ok so you've cut the stock connectors off yourself and done this. You get what I'm saying right ? Why did you not go the much superior Bosch EV14 injector ? The Denso /Sard injectors are not cheap new for such an old design.
Yeah I understand what your saying it was strange the injectors where brand new unused.  I ended up buying them for a really good price , I couldn’t say no to it was a good deal i was after hks1000cc ones and has one lined up new and the deal fell through, I am gonna run e85 now late change of plans on the build I’m hoping they can get me to 400akw or near that
The HKS / SARD / Power enterprise injectors are all SARD injectors and are not meant for E85 like the Bosch EV14 though. The 800cc will surely be too small for 400akw on E85 as they will struggle to do that on 98 unleaded.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
