Hey Guys,
Does anyone know the part no. for the wheel nuts for these Enkei wheels? or alternative wheel nuts?
I want to put these on my V35 sedan.
I spoke to Nissan and they have 2 part no.'s for the 370Z's
40224-JK00A, pre 2015 and 40224-4HH0A for the newer versions.
Cheers
https://www.sau.com.au/forums/topic/478552-v36-enkei-wheel-nuts/
If you are running stock wheels, you will need to get the stock nuts. Aftermarket ones will not fit properly, unless that's changed since I last checked 2 years ago.
The part number you are looking for is 40224JK00A.
  • Thanks 1
Really :O
I did not know that. Interesting to know you have to only run OEM.
Cheers. Ordered the OEM ones from Nissan. $136
8 hours ago, DashyyPC said:
Really :O
Yea tell me about it. I'm on my 2nd set now and it seems like its on the way out. Some of these OEM parts I swear are shite.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
