HAHA you are not a true import driver in victoria until u get canaried!!
Welcome
If that's true, maybe i should sell my line.
On the other hand; having a big turbo hanging off the side of your RB does not make you a true import driver, just like owning a GTR does not mean you can "drive" a GTR. Lets see who's worthy on the track, you dyno queen! ;):)
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-967605
On the other hand; having a big turbo hanging off the side of your RB does not make you a true import driver, just like owning a GTR does not mean you can "drive" a GTR.   Lets see who's worthy on the track, you dyno queen! :D:rofl:
when i have a license again i will be out on the track :D
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-967732
You will need to get a standard BOV for removing that canary.
A switched on VICRoads person will pick you up for it.
If you know the tricks then vicroads wont even look at ur car when you go to clear a canary so you dont have to take anything off. :D
I have explaining this so many times before
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-968505
Obvously his trick is someone on the inside
An INSIDER...ive heard if urve got a mate who works for vic roads...you can get off scott free everytime
yes if you know someone at vicroads then you can get the canary cleared 5 mins after the cops give it to you, but that aint my trick, and i dont have a trick either, its just a way of going about it, no tricks involved :)
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-973350
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
