  • Replies 70
Posted Images
Guys after many hours. I found these on ebay. U reckon these are cheap?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33741
All the places in aus i rang said the 1 inch of silicone hose was like 15-20 bux. I cant vaouch for the quality of the ebay stuff but it seems i can get like 40 incehs for like 100 bux and 18 bux delivery whihc is like much cheaper than here.
Also found reducers for like 11 bux each. Her in AUS I was quoted like 40 bux a reducer. WTF :bs!:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33742
Unless u guys can get me better im gonna go with these. When i start this project.
hey i noticed you fellas using mild steel piping, im currenltly in the process of removing this from my car after it has rusted and is blowing chuncks of shit into the engine, how are you guys getting around this?
waldo - did you paint the inside of the pipe as well ? I think I might try and paint the inside aswell.
A second set of hands does wonders.
To put the front mount on yourself, heres how i did it. sit on front for the bar with legs extended and place cooler on your knees. bend knees to lift cooler up and bolt it in. This was soooooooooo gheettooooo.
Well the cooler is on now on my car. will take pics.
anyone that wants to weld the pipes together yourself * hint * have lots of practice first.
I botch my job up, I used an arc welder $109 from repco * im poor, if i could get a mig i would *. so the rest of the welding was just to join the pipes together to hold and I placed the silicon hose over the top and bold it down.
I will also use the welder to put a lip on the pipes so that its harder to slip off.
pipes all up was $110 from livo exhuast
3#-> 2.5# reducer hose @ $25 each X 2- Shift perfomance
2.5 3inch hose @ @ 20 Each
t-bolt clamps @ $13 each X 12
bracket i made, its bolted on where the horn used to be
http://www.tygarbyte.com/huev/images/inter...racketmount.jpg
I grinded that lump to make the surface flat. and then painted it.
height from the ground.
total days to install all by myself ? 4 dayssssss.............. got freakin sunburnt doing it tooo.
Hopefully i should have it completed tomorrow.
where did u buy piping and silicone from
it would be less for pipe work and silcone i paid around $240 all up
nozila- check lazy bastards pics out he was the one who did it before me on his 33 look up a couple of posts and u will see him
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
