worth playing, but if its not your thing, its not your thing..
Like skyzerr33 is saying, not much too it really.. and if you want a more complex shooter there are others around. Anyhow, its keeping me playing. I'll probably endevour to finish it, and I don't finish too many games.
Works on older systems and scales pretty well down to older systems, but you only get 640x480 and medium or low settings. Meant to be ok, but would take away a fair bit of the atmosphere in a game like that i reckon.
runs nicely on mine with high detail with 1024x768 w/ Athlon XP3200+, 512mb RAM, and 9800pro extreme overclocked to above 9800XT speed. Wouldn't want much slower than that to get the full effect.
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-969548
My day at work today:
Install 256MB NX6800 card.
Install Doom III
....errr......something goes here....bit of a blur really :D
Stop playing Doom III
Went home from work.
I like it but would prefer the system our video card rep plays it on:
Athlon 3800+
2GB RAM
400GB S-ATA HDD
Abit 512MB Vid card
In ULTRA quality (or whatever it's called) @ 1600x1200 at 68FPS !!!!! FARK!!!
Adrian
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-969610
lol got to try it waiting to get it off mate Shound go good on my
set up of
P4 3.0 ghz800mhz fsb @3.4ghz
Geil PC 3200 DDR ram 1gig dual channel
MB Abit IC7 MAX 3 i love this board
ATI HIS 9800 Pro IceQ @ past XT speeds
Housed in Thermaltake Xaser III 2000A
550 watt Antec True Control
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-970674
later this year i plan to buy my new PC from a friend who builds custom PC's with these specs:
3.4 Ghz Processor
1 GB DDR RAM (more if financially + physically possible)
200 GB HDD (need space for my muzyk)
17 inch LCD display (thinking about 19 inch)
8 speed DVD burner
And some other wierd computer gizmo's which i have no clue about...
He quoted me $2200 - $2500... is that a decent price??
https://www.sau.com.au/forums/topic/47932-doom-3/page/2/#findComment-971877
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
