Hi All
I used to be active on this forum a while back as Ssshonky, but since then a lot has changed, had two kids etc etc.
To cut a long story short, I still have my C34 Stagea, it has seen a few k's by now and has blown a head gasket, so I am in the process of stripping it down.
The exhaust and inlet manifolds are off, and I have the motor at TDC, ( Checked the marks on the inlet and exhaust cam gears ) but I have realised that I should have cracked the nut on the crank before the car was torn apart to the stage that I can't start/turn it over. I have read a few posts that advise you can get to the crank via the sump, but my question is do I need to take the crank pulley off at all?
I can see a marking on the crank that will show me if I have moved it at all, so I could get it back to the original location.
The timing belt looks in fairly good condition and I am thinking that I should have enough slack to get the cam gears slipped off the belt without undoing the crank nut. Thoughts?
Am I doing it the 1/2 assed way? I just don't want to have to do more than required, but I also don't want to put the thing back together and have it go bang.
I don't have enough room to get a rattle gun in there or I would have done so :)
Thanks in advance!
https://www.sau.com.au/forums/topic/479502-returning-member-in-need-of-advice/
Sounds like you can still crank it to undo the nut. Don't need inlet manifold or exhaust for that, it is better if the car doesn't start!
You will have pretty much no chance of doing the head without backing off the tensioner for the timing belt. And if you do manage to get the belt off the pulleys I can't see you getting it back on.
Hi Ben, thanks for the response, it's really appreciated
I was thinking that the motor would not crank over at all without all the bits and pieces like the crank angle sensor off etc, The cam covers are off and the coil packs etc are all out. I guess you are implying that the starter motor will still do it's thing yeh?
I was thinking the same thing about getting the belt back on without access to the tensioner but the motor only has to turn a bit to crack the nut
The starter motor will do its thing no matter what! (aside from an aftermarket immobiliser doing its thing)
Yeah so I cranked it over and the nut cracked no problemo ... I was expecting  a much more dramatic result.
So now it's all off - I am just trying to find someone with a pulley puller I can use.
I know people can be funny about loaning out tools , I go by the motto of
Never loan out your wife or your tools cause they will both come back ... ( you can work the rest out )
Thanks for the help, I should get more involved in these forums again , I miss the camaraderie
Im hearing you they will come back expecting a better life I can't provide. .....
Where are you located?
  • Haha 1
Hi all
@KiwiRS4T thanks for the link, made life so much easier
Ended up getting a kit from supercheap for not a lot of $$ and it came right off like a bride's nightie.
Making progress but just making sure it's methodical so I don't fck anything up
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
