So my front emblem on my R33 GT-R was badly stone chipped and the rear emblem Red was faded.
Cleaned out the old paint with paint thinner. Mixed up some resin epoxy with red stain and poured it in.
What a big difference and so much easier than trying to paint.
  • Like 3
https://www.sau.com.au/forums/topic/479936-gtr-emblem-refurbish/
  • 1 year later...
So how did you pour the epoxy without it running out or dripping? I would like to try this. If you would like to talk more my Facebook is Nismology and IG Nismology_33.
Thanks again
well ill be dipped what a not bad trick. i just spent 300 bucks on a new oem one......idiot. nice trick here mate im gunna give this a shot with my old one
