1993 skyline r33r impul 4 door
2.6 gtr motor single turbo
5 spd twin plate clutch
Gtr brakes with flexible braided lines
In tank internal pump to swirl pot to 2x external 340lph bosch fuel pumps.
Link ECU
Yolk 18x235 front and 18x265 rear rims.
Tien adjustable coil overs with adjustable dampening control unit in dash. Also whiteline front and back stabiliser bars. Handles good for age.
Engine had extensive work internally. Crack tested, blueprinted and balanced. All aftermarket exceeding 50k to build. All engine work done by all star garage Perth.
Currently driving with stock lsd but have a tomei locker included, just in pieces chasing bearing and seal kit to rebuild.
3" stainless Jasma exhaust with screamer pipe too.
the last photo shows the front bumper not the best and bonnet got a dent at the very front. All up probably 5 to 6 minor dents and a few stone chips but overall still a really nice car with no major work to restore to its former glory.
Really nice to drive and a headturner too not to mention eats hsv gts's and fpv gt's for breakfast!!! Not to mention gtr's,  gtst's too! Very hard to obey the speed limit and nothing sounds better than hitting boost hearing the screamer pipe do it's job!!!
I want 20k firm, no dreamers, no tyre kickers and if you know what your looking at price self explanatory. I'm not desperate to sell and the longer I have the more I will do to it and probably decide to keep. Please text me to enquire and a good time to ring you as I work long hrs. Thank you.
Email [email protected]
Phone : 0477582361
20200409_211042.thumb.jpg.10b3006784e58b1fe548afa323ab8f9b.jpg20200409_210926.thumb.jpg.2122cfa5647522e22880396b64fbcb40.jpg20200409_210942.thumb.jpg.16f48f1ccff28d4447db2f864b22dbe9.jpg20200409_211134.thumb.jpg.32e8afc28ce065bfaa2218580bd76364.jpg20200411_090320.thumb.jpg.a4ebbb00274d324f798926e6fbf0843e.jpg20200411_090336.thumb.jpg.7e3e56c30a0fe2d3bd0bbcb3f7eadf0f.jpg20200411_090431.thumb.jpg.54abdccbd81c6e7bb4e6f6f7fdb9cc48.jpg20200411_090542.thumb.jpg.7b7f88881a0034bde8b3dfa593dbb250.jpg20200411_090606.thumb.jpg.2142dca543e232b4c47bea6c17f83ce8.jpg20200411_090555.thumb.jpg.6dac7b4abcda98c7c86802a28a75e163.jpg20200411_091420.thumb.jpg.d2ea7b8bbc20c104d4d3eb868bda65b4.jpg20200411_091545.thumb.jpg.98051c0eb8f1a352c0850c8adbde4a86.jpg20200411_092647.thumb.jpg.b65fac54d86891e4bebbaab9d76b73ca.jpg20200411_092134.thumb.jpg.0011d254ec684fd212181a4ceb4bc2c9.jpg20200411_104243.thumb.jpg.ecc19c1a436607e0bf30b76b86b173fb.jpg20200411_092003.thumb.jpg.3ecea17aaf6ac02db654dafbd8b5dac8.jpg
https://www.sau.com.au/forums/topic/480137-1993-r33r-impul/
  • 4 months later...
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
