G'day guys and Gals, my name is James and i have just purchased a Nissan Stagea M35 and as always joining in with the culture to tap into some wisdom and learn as much as i can about my new toy.
I used to live in the car scene but after becoming a dad several times i moved into functionality over desire but now im trying to find common ground :)
Look forward to checking out your rides :)
https://www.sau.com.au/forums/topic/480248-gday-gday/
Hi James! The Stagea section is named "Wagoneers" now and you will find a wealth of information there. Someone has even summarized a lot of the M35 information in one thread...
https://www.sau.com.au/forums/topic/480248-gday-gday/#findComment-7929651
Thanks mate, spent most of the night reading through picking out things to have a look at so now to get on with it :)
https://www.sau.com.au/forums/topic/480248-gday-gday/#findComment-7929653
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
