Hey guys,
Although i am in the UK, hoping you guysc an help me out with identifying some OEM shock absorbers i can get for my R34 GTT.
I tried looking at the KYB & Monroe website for OEM parts (i got a standard R34 GTT) , but nothing shows up  :(
I cant imagine the the GTT has specific shock absorbers that no other car uses  (I wonder, given the rear brake rotors on the GTT are the same as the Z32  300zx/Fairlady , wonder if the shocks are ?? )
Trying to either find the Nissan OEM number, or the KYB part number for the shocks, or any standard OEM spec shocks i can use ?
Any ideas ?
https://www.sau.com.au/forums/topic/481834-r34-gtt-oem-shock-absorbers/
Do you want to be cheap? Or do you want to buy decent dampers? Because Bilstein B6 is the minimum that I would recommend for direct fit dampers.
Nothwithstanding that, I just typed "r34 kyb rear" into google and the first 2 hits were for an eBay listing and the actual web shop of this crowd here in Oz offering this https://www.superspares.com.au/2-rear-kyb-new-sr-special-shock-absorbers-for-niss~12193763
cheers for reply, not looking for cheap, just oem (standard car).....
I found the original part numbers last night, and the SR range of KYB for the R34 GTT  (same as your link)..
The idea was to buy OEM shocks, and add my Tein S springs to the shocks (already bought the springs before my pal told me i got x2 leaky shocks) .....
Being in the UK, coilovers are easier to obtain that shocks!
Selected Vehicle:
NISSAN SKYLINE R34 ER34 05/1998~05/2001 2 Door Coupe 2.5 litre, RB25DET I6 24v DOHC Turbo MPFI {208KW} RWD,AT/MT,[JAPAN] 12272
Shock/Strut - Front
image.gif.6280203887490948211e6610e1fa5d02.gifA12C6E050DA21BF458277473440D1DAE3F0A1B0612CB7F983FAB3430EFF3C0AB.jpg NSF9092
New SR Special - Enhanced Performance
2 req
Shock/Strut - Rear
image.gif.7913e75b64ab70f76943c3d75e0ccdae.gifB17930682718FF60403DBE2831C80BA316E2DA175F775161D39B804AA5C6ACA9.jpg NSF9093
Suits Lower Eyering Mount Type
2 req
image.gif.9e6349fdf5e9c0b867aa5df3a3bdfc38.gifB9231E6738C028BA6761DCDFCCD05568A349DBB80C78E24729E4E8E81FFBC2D3.jpg NSF9095
Suits Lower U-bracket Mount Type
2 req
Those Bilsteins above are for the GT with eyelet bottom. The GTT has fork bottom, like the GTR. But you can get B6s and B8s for GTRs, so I can't see that there would be too much trouble getting one for the GTT. I mean, superficially, you could just put the GTR one in. It will fit.
cheers guys
Turns out, i need to send my springs back to the supplier, and get coilovers instead...
And yes,I was looking at OEM (nissan), or a manufacturer that made OEM spec shocks for the car..
As said, mine is standard, but at the same time, was trying to keep my costs less when buying shock absorbers, compared with buying Coilovers....
The B6 & KYB SR shocks, even the Nissan OEM shocks = cost more than Tein Street Advance Coilovers.....
So end result is, i need to switch anyway....
Cheers for the replies though guys :)
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
