Bunch of soccer mums :D
aaaah!!....but soccer mums with STYLE :wassup:
did I say I was selling??? I must have been having a bad hair day.
I just swapped my bonnet pins for recessed Ford XA ones, closed off the top and sides to the radiator. Will sheet in the bottom tomorrow. Hmmm! what's next on the list?
Selling??? I just bought another one so it won't be lonely at night :headspin:
Damn you Jay,
you said you were selling the fourdoor and transferring evrything to the coupe :P
:P
Sorry Nex, I did actually say that, I think I had one of my rare moments of sanity and thought I couldn't justify having 2 Skylines.
Fortunately my normal state of mind quickly returned and I realised I don't have to justify it. Anyway the white car only has 2 doors so the track is all it's good for :wassup: and jlnewton will need someone to wave to without slumming.....so the 4 door STAYS. :D
  • 3 weeks later...
  • 3 weeks later...
Andrew how can you make a comment like that when you list a CHICK's car (KA Laser) as your ride. Won't your mum let you drive a real car ???
I dont reckon you'll be able to find a chiq who actually wants to drive brutis :)
Possibly you refer to a standard (and, well, working?) KA :S
Anyway, I've got a sports car. Its got 2 doors. :)
Hey, soccer mums Aust. pfftttt. lol
The sedan is starting to look the goods with bilstein shocks, king springs, dba slotted 4000 rotors and R33 GTR rims. certainly no soccer mum car. hehe. Currently doing the stereo, respray and tint. Should be sweet as then.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
