I am very pissed off.
I am now dealing with their Forrestville branch for the first time tomorrow.
The Forrestville branch painted the car this time round.
Overall quality is great this time, just a pitty about the buff.
I wonder which branch did the buff.
Lonsdale or Forrestville.
  • Replies 56
yeh don't touch the car, just take it to them to do the work, the latest paint job looks a lot better than the last 1, much better peel, don't take it back to that first shop ever again, and hurl bricks through their windows for good measure, this latest problem shouldn't take too long to fix, although u really aren't having much luck with panel shops, what panel shop did u say it was (the first one)? is forrestville insurance company or panel shop?
The paint is pretty good this time. I am happy with it.
Its impossible to get no orange peel but this time around its consistent and standing back it looks perfect.
The close up shots I took before obviously show up peel that cannot be seen under normal circumstances.
Shall have to complain about insurance company paying for taxi rides to inspect work. Mind you, my mom got picked up in a shauffer driven car to collect hers. either RACV or pensioners.
I wouldnt go near a lawyer yet. Unless it is a no win no fee case, it will cost more than $50. First step should be small claims tribunal, but i suggest just being polite to the manager about work.
Hey Joel, if you are up Tea Tree Gully way any time drop on bye and see what a good respray should look like. (got mine back a week ago) It took them nearly 10 weeks, the last 1.5 weeks spent pollishing and aligning panels, but the results are worth it. (no orange peel, no buff marks)
Dont settle for second best, if they couldnt do the job then they shouldnt have acepted it in the first place.
I will take you up on that offer 4door. :)
Can you drop me a PM?
I got the couple of white bits buffed out today.
They also buffed up the front bumper.
It looks good now but I can still see the odd little bit of white on certian bits.
All it needs now is a good buff.
I'm happy with it now.
I need to realign the front lights and rear lights.
I swear the pricks did it on purpose.
One of the rear lights is sunken in too much the other is sticking out 5mm.
Bastards.:throwup:
When you say that some of the job was insurance and the rest was "private". How much of it was private and how much did the original repsray cost you? Just wondering cause I'm in the same predicament atm. Second time the cars gone back and I'm not happy at all. I'll see how it comes out this time.
I was told that a $2300 "white repsray" was a cheap job? And the orange peel was the different between a cheap and an expensive respray. To me, $2300 aint cheap (with a little ice pearl thrown into the clear coat) job. Seeming we are giving him another go, I won't post pics of how crap it looks just yet. But yeah, just wondering how much it originally cost.
that is fairly cheap, it depends on where u go because some regular panel shops don't like doing resprays, u hav to shop around, $2300, is that to fix all the dents and what not? or just paint?
Guest RedLineGTR
silver is the hardest to match though, u can never get it perfect, even getting it close is quite hard
Yep silver is the hardest to match & Black is the hardest to spray because every little detail comes up and it takes a good spray painter to get it smoothish, unless you add a clear coat and use multiple layers.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
