Hey guys have a 94/95 33 gtst with a rb25det in it, stock apart from, fmic, Toyota Yaris coil pack mod, ems 8860 computer, 3inch exhaust, walbro 255Lph pump.
now to my problem, 2 weeks ago I wasn’t getting any luck starting the car, bought a walbro 255 Lph fuel pump installed that, still had no luck starting the car, replaced coil pack plug connectors and remade the harness, car now starts yay :) but it idles very very rich, Tech edge Afr fuel guage reads ‘rich’ lumpy idle heaps of black smoko coming from the exhaust. Installed an adjustable fuel pressure regulator set the psi to 20, car ran a lot smoother but still read ‘rich’ on afr and black smoke out of the exhaust, have changed the spark plugs over, have triple checked vacuum lines can’t find any unplugged or splits in the lines, cleaned iacv, cleaned maf sensor even tried a friends still didn’t work, does anyone have any ideas of what it could be or where else to check I’m losing my sanity, cheers heaps
https://www.sau.com.au/forums/topic/483596-rb25det-s15-rich-idlemisfire-2k/
What diagnosis did you do to determine faulty fuel pump?
Adjusting the reg that low will cause problems.
go back and...
set fuel base pressure to 45psi
install fresh plugs
Connect to the ecu
Check to see if all connected sensors to ecu are giving correct readings
If not replace faulty sensor
Idle afr should be around 14.7 doesn't have to be exact.
If this is beyond your skill set find a decent shop to look at it and sort it
On 4/28/2022 at 9:34 PM, Ben C34 said:
Car out of no where runs mega rich, and you have changed regulator leaves just injectors and ecu.
Or intake air temp sensor. Starting with easiest what is your intake air temp ?
IAT or TPS would be my thinking or "Was running fine than I replaced this and that now it has an issue"
go back and...
install fresh plugs
Connect to the ecu
Couldn’t hear factory pump prime, plugs weren’t wet, replaced with new pump, can’t connect to ecu, unsure if it’s because it’s so old and no latest software updates or plug in ports damaged internally, bought a new cord to connect and no luck (EMS 8860).
have tried letting the car idle and taking out coolant sensor all that happened is it idled abit worse but didn’t die. Also let car idle on the maf that was on it when I bought it, in plugged and car still ran, swapped with another pink maf, unplugged on idle and still ran, cleaned o2 sensors and car ran at 0.80 Lambda instead of the usual 1.0, after starting it this afternoon the afr guage reads ‘rich’
Can’t get into ecu to read if it’s set up in there but I’d say anywhere  from 25-35° cool outside but hot in the shed after abit, any way to test injectors? Family member asked if it has a cold start injector like his VL had, Is the cold start valve possibly staying open?
you need a laptop with windows vista or Xp and a serial port.
Cleaning the Wideband sensor will have killed it 1 Lambda is Afr 14.7 on petrol and .8 lambda is Afr 11.7
There is no cold start valve, IAC will allow more air to pass at start up.
As stated will need to connect to ecu for sensor data but due to EMS being closed for so long, hard to find software and older laptop probably up for a whole new ecu setup.
Depends where located a decent shop may have something to access ecu, I know I do.
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
