S
Hi all, so I have a problem with My RB26.
Sometimes upon startup a tick noise is intermittent or continuous. This noise slowly goes away. And yet sometimes like today, after fresh oil and filter, primed with cam trigger disconnected blah blah, started ran so quiet for roughly 10 mins, then tune changes to ghost cam idle once warm, the tick came back instantly as soon as the idle changed.
Stock head, stock oil pump, tomei Hg,tomei head studs, oil restrictors, still twins. 90k km engine. Runs 5w50 or 10w50.
Pulled oil filter apart to inspect. Nothing clean as a whistle.
Comp is all 155 160 across the board wet.
Can anyone shed some light? Got me stumped.
I have videos of it Running on start-up, then once the noise came. Wish I had video running when it happened.
Cheers 🍻
https://www.sau.com.au/forums/topic/483793-rb26dett-tick-noise/
narrows it down a bit.....timing cover (maybe foreign object or something broken off and bouncing around) or cam covers (nasty, could be a cam oiling issue)? Cam covers are pretty easy to take off and have a look for anything amiss.
Injectors are often noisey but you should be able to isolate that (and they should not get noisey then quiet.
Well, ticking lifters is usually just a (lot of work) clean, soak in oil, reassemble, or at worst, replacement, exercise. But solid lifters can only grab in he bucket bores if something has been damaged. Scuffed, squeezed, broken fragments of something else stuck somewhere, etc etc.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
