Seriously, everything that could have gone wrong this weekend has.
I'll update the issues I've had shortly but currently the hub and knuckle will not seperate from the drive shaft. I've tried bashing it (ha!) And I now have a 3 claw puller on as hard as I could (like shortly a crap load) and then bashed it again (ha!). No luck. I then left the puller on and heated it up with my propane torch for about 5 mins. And bashed it (ha!)
So the puller is still on. I was hoping that the constant pressure over night might help? After that I'm at a loss.
(Btw bashing it with a heavy plastic hammer so drive shaft and thread safe)
What the hell do I do now?
Thanks
C
Did you take the nut off?
OK kidding! But put it back on so it is just before level with the end of the driveshaft, then bash that (straight on) with a heavy metal hammer
  • Like 1
Nut is off but I did leave it there to bash earlier. I'll try my little sledge on the but but it sits recessed into the hub so hard to hit with anything sizely.
In that case, leave the socket on there and bash the back of the socket :) (hopefully its an impact socket)
Its tricky to give specific advice without knowing the exact setup (which model skyline is it?), but I guess it is something like aluminium on steel galling, so heat and shock are the answer
  • Like 1
Yeah der me. Can definitely leave the impact socket on and bash that.
Oooh D.. you crack me up 😂
On 31/07/2022 at 6:20 PM, joshuaho96 said:
Do you have something like this to help you push the axle out?
Yep I have a puller on now that I'll leave over night. It's as tight as I can get it. 😞
On 31/07/2022 at 7:29 PM, White GTS-T said:
Hit the end of the puller with a hammer (serious) while it is tight. You'll find once you shock it, you can retention the puller tighter, then repeat the process.
I was actually going to ask that considering it's adding pressure. I'll whack a socket on the end so I don't kill the top. Thanks!
Dumb idea but what if you use some refrigerant out of an air duster can upside down to cool the axle instead of trying to heat it? I did that with my rear block heater pipe and it helped it work loose.
  • Like 1
Ok, so I made some progress. I managed to get the hub/knuckle off but not before pulling my whole bloody driveshaft out of the diff, but thats another problem.
This is the BMW E90 rear hub / knuckle set up;
https://www.realoem.com/bmw/enUS/showparts?id=VB33-USA-08-2006-E90-BMW-330i&diagId=33_1230
And this is the hub / bearing;
https://www.realoem.com/bmw/enUS/showparts?id=VB33-USA-08-2006-E90-BMW-330i&diagId=33_1231
My question is, I managed to press the bearing into the knuckle and then I started to press the hub into the bearing (which was seated in the knuckle) and it was slightly off straight, so I stopped and when I took the hub out, it took the top of the bearing with it. Nothing seems wrong with the bearing, just appears to be a cover. It seats perfectly fine back on there and after pressing the hub in again (straight) everything seems smooth and quiet. I have a spare bearing (always buy 2 when you break things as often as I do) and wondering if I should swap them over?
Thanks guys.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
