It’s me again with another problem (face palm) So I’ve had my stagea for around 8 months now, pretty much from since I’ve had it the 4WD Light has been on and off intermittently. Last scan said “pressure sw [on failure]” not sure which ecu they scanned but I didn’t muck around and ordered an after market pressure switch from Frenchies Performance Garage had it installed with my manual conversion. 4WD light was still there, mechanic told me they bled the system and it still wouldn’t work and they think power is not going to the pump or something… so I took it for another scan at my local and they said there was no error code just gearbox code so I’m assuming they scanned the main ecu and not the attessa ecu, but did say the 4wd light was gone. But like I said it’s intermittent, it came back after a long drive. So any ideas what I can do next i really want to get the car on the dyno this month.
I’ve also tried pumping all tyres equally as front left was low pressure and still, 4wd light is intermittently active. Also the atessa fluid is always at the max line doesn’t change when car is on or after a drive.
Car also has a slight ringing noise towards the rear wheels on either side that doesn’t change in volume or pattern it’s just a constant ring, I don’t know for sure if it comes on when 4wd light is on but the noise is also intermittent. (If that helps)
Car is in the shop getting parts installed so I can’t do much at the moment but hoping for some ideas.
This was the first scan error code not sure which ECU
Edited by SLIXK
https://www.sau.com.au/forums/topic/483903-4wd-light/
Does the 4wd actually work at all? Since it is at a shop they could put it in gear on the hoist and make sure all 4 wheels turn. Potentially not being able to get pressure in the system would look the same as the switch failing because it would always be on. Increasing numbers of R32 owners have had to replace the nitrogen cannister to get pressure in the system (otherwise the relay clicks regularly as the pump keeps turning on.
Since the scan tools are not nissan consult, they may or may not be able to read the attessa computer as well, so the second scan not finding anything may not mean too muc.
https://www.sau.com.au/forums/topic/483903-4wd-light/#findComment-7968448
I’ve never heard any clicking noises before. Shop said they’ll ask the sparky who’s relocating my battery to have a look if he can find something wrong! But he did say he will chuck it on the hoist when he gets it and test if all 4 wheels spin.
https://www.sau.com.au/forums/topic/483903-4wd-light/#findComment-7968451
On 8/2/2022 at 9:30 AM, joshuaho96 said:
Yeah, if the pressure switch is working correctly the most plausible explanation is your nitrogen canister/accumulator is dead.
Is the canister refillable or would I just purchase a new one? Does Nissan still make them? Is it easy to replace?
https://www.sau.com.au/forums/topic/483903-4wd-light/#findComment-7968452
You would buy a new one unless you really want to refurbish it as some kind of special exercise. Nissan still sells them. On some cars they’re easy to access but on others it can be a big pain in the neck.
https://www.sau.com.au/forums/topic/483903-4wd-light/#findComment-7968457
Might just look into buying the canister to eliminate that potential.
https://www.sau.com.au/forums/topic/483903-4wd-light/#findComment-7968458
On 8/1/2022 at 5:44 PM, SLIXK said:
Damn, so how do we test if the canister needs to be replaced?
Test the line pressure to see if the pressure switch can be trusted. If the switch triggers at the factory spec then you can probably trust that it's working all the time. Jiggle the wiring to see if the signal is dropping out due to a harness problem. From there see if the pump is turning clicking on more often than it should. If the pump is running all the time and you aren't leaking fluid somewhere the problem is likely the canister has leaked its nitrogen charge.
I recommend whenever the light comes on you should figure out where the ATTESA control unit is and check the code yourself. Would suck to spend 465 AUD only for that to not be your problem. Could be something else entirely.
  • Like 1
https://www.sau.com.au/forums/topic/483903-4wd-light/#findComment-7968464
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
