DominusUniversi Posted September 21, 2022 Share Posted September 21, 2022 Hey guys, I'm having an electrical issue that I can't seem to figure out. So my interior light works fine in the on and off position, but when it's in the 'door' position, the light won't turn on when the door is open. The only time the door light on my dashboard works is when the car is on. I've attached a video down below, hopefully it explains my issue. Any insight to what it could be would be great. Thanks in advance guys! FB_VID_840167655689649516.mp4 Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/ Share on other sites More sharing options...
GTSBoy Posted September 21, 2022 Share Posted September 21, 2022 Corroded door switch. Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/#findComment-7970299 Share on other sites More sharing options...
DominusUniversi Posted September 21, 2022 Author Share Posted September 21, 2022 24 minutes ago, GTSBoy said: Corroded door switch. Could it be? The door light won't even turn on when I open the passenger's door? Are they all wired together so if one fails it all fails? Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/#findComment-7970301 Share on other sites More sharing options...
GTSBoy Posted September 21, 2022 Share Posted September 21, 2022 Alright then.....broken wire. Grab the wiring diagram and follow the wires. You'll find it. 1 Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/#findComment-7970302 Share on other sites More sharing options...
DominusUniversi Posted September 21, 2022 Author Share Posted September 21, 2022 46 minutes ago, GTSBoy said: Alright then.....broken wire. Grab the wiring diagram and follow the wires. You'll find it. Thanks for the help! I'll get to cleaning the switches and inspecting the wires tomorrow. Appreciate it! Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/#findComment-7970305 Share on other sites More sharing options...
sinn3r Posted July 19 Share Posted July 19 Any update on this one? did you manage to get it fixed? i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/#findComment-8002902 Share on other sites More sharing options...
DominusUniversi Posted July 19 Author Share Posted July 19 2 hours ago, sinn3r said: Any update on this one? did you manage to get it fixed? i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good. 1 Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/#findComment-8002904 Share on other sites More sharing options...
GTSBoy Posted July 19 Share Posted July 19 5 hours ago, sinn3r said: Any update on this one? did you manage to get it fixed? i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement And R32 has none of that smart nonsense that the R34 has. It's all simpe stuff on the older car. 2 Link to comment https://www.sau.com.au/forums/topic/484061-r32-skyline-interior-door-light-issue/#findComment-8002910 Share on other sites More sharing options...
