testing the motor is pretty simple, there will be a 2 wire plug that goes to it. Apply 12v (eg from a battery) and it will go down with the wires one way around, and up with wires the other.
thank you will try this
  • 3 weeks later...
finally got some time to try this, nothing.
cant even hear the motor making any noise
same to assume motor is done, if so how to remove it now is the question lol
1 hour ago, Duncan said:
yeah if you are certain you connected the motor's terminals properly to a battery (both ways around) and no movement, then the motor is dead
im having trouble finding a good guide for s2 passenger side window motor removal
On 1/28/2023 at 2:45 PM, GTSBoy said:
You don't need a guide. Just start taking the door apart. You'll soon work it out. Not to mention that the factory service manual will have everything you need.
do you know if the whole window regulator needs to come out? or can I remove the motor without removing the whole regulator system
On an R33, no I don't. To be honest, I don't even know if you can get just the motor out on an R32, and I'm not at home to check my R32 workshop manual (or the R33 one that is there, either).
I have a couple of spare R32 mechanisms in the shed, and just looking at them (or, in this case, the memory of looking at them!!) suggests that you probably have to pull the whole lot out. But I shouldn't imagine that it's much more work anyway.
  • 1 month later...
I got around to removing the whole mechanism, replaced the motor and everything. wasn't the problem, still not working, window still moves down, but not up, switch looks fine don't think its that, went to check the window relay as that seems to be a potential issue, assume it would be on drivers side door so I removed everything and checked and it's not there, do you know where its located on an s2?
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
