Hey all im new here.
Just wondering if any ppl on these forums go to Swinburne Uni in Lilydale? or live around the area of Ringwood / Croydon / Kilsyth / Ferntree Gully.
Reply to this post with your car details and i'll keep a look out for ya at Swiny or around your area when im there next :)
Cheers
https://www.sau.com.au/forums/topic/48465-swinburne-lilydale/
sweet man!! come say hi
be good to meet more ppl!!
i only had my car for about 2-3 weeks
I seen a real tidy three two at swiny only once but. was on a day where the tafe had a free bbq. about 2 weeks ago maybe. Had white rims that where about 17inch and was an auto. Is that ur car AWDMAT?
what days do u go to swiny? i go MON, TUES, WEDS. i study Multimedia CERT IV in the tafe department. Drive a Mazda 323 Protege thats dark green.
Im Sean by the way :D
hope to see you all around
yeah thats mine man!!
i go tues, thurs and fridays
catch ya round sean
Hey dude what time do u go to swinny on a tues?
im there 9:30-4:00
if you go same hours we should meet at a certain time that suits us both in say the bottom carpark where no one ussually hangs out. that way we can have a chat and i can check out that monster of urs!! i think my lunch brake is 12:00-1:00 but i get heaps of '15 min' breaks as they call them. hahaha
hey man.
meet me at the bottom carpark at 12:10.
ill check this thread at 12:05 and if u havnt replied we'll do it another day.
soz it took so long for me to get back to you. this forum is having probs.
p.s. ill be wearing a white hat and brown top. cu there hopefully.
make sure u reply!!
Alright Swinburne....You wanted the best....You got the best...
Meet and Greet for anyone on this forum that goes to Swinburne. details as follows:
Date? Tuesday 24th AUGUST
Where? The first carpark on the left as you first come into Swinburne Lilydale. (gravel carpark)
Time? 12:30pm
Hey im not expecting much of a turnout, 3 at most im guessing. So i hope you guys can make it. Even if you can just come and say hi quickly that would be cool. Good on ya fellas. See you there! ;)
P.S. either reply to this post or send me a private message letting me know if you are coming
im up for a bit of a meet up cyco
let me know when and where
No worries, haven't got any cruises organised just yet, however I'll be going to the SAU-Vic meet / barbeque at Albert Park on 12/09/04
.:SAU-Vic Official Membership Take-on Meet:.
A few of us could meet up beforehand (around 11am, Eastland carpark maybe?) and convoy towards Albert Park from there.
I'll post a Melways map ref / route closer to the date, if you're interested
Guest Flawless
No worries' date=' haven't got any cruises organised just yet, however I'll be going to the SAU-Vic meet / barbeque at Albert Park on 12/09/04
That'd be cool!
:ghost:
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
