CES Split dump pipes
  • Replies 56
Guys, CES is one of the Best exhaust fabricators in Australia
Goto www.cesracing.com.au to read about them
All ive ever heard about CES has been good
$650 for this; HPC coated is awesome!!
If we get 10 im in definate.
Guest darrinspencer
Wizard count me in for sure as long as i can pick up the dump pipe within the next couple of weeks. I am very interested... Also what would be the difference between the plain steel and the HPC coated?
The $650 price is for 10 steel pipes HPC coated
If we split them up, some with HPC and some without It will adjust the $650 price
Prices quoted were broken up as
10 pipes $530 each plus hpc $120 each total $650 each
5 pipes $550 each plus hpc $130 each total $680 each
So depending on what option we end up with the final cost may be affected
One thing Trevor suggested was that on Skylines with their fairly low mount of the turbo the HPC would have a less of affect and you could get away from not using it.
Apart form the high heat reducing affect from HPC, it also stops the mild steel pipe from rusting, which IMO is worth while.
There seams to be a few GTR owners keen to participate in this group buy. If it was possible to include dump pipes for an R32/R33 GTR in the group buy I think you would make up the numbers required a lot quicker. I would be keen for starters...
Lawrence
Guest darrinspencer
Lawrence
We need to get 10 people for 1 type of dump pipe not a mix up of both
CES make 10 at a time, hence we need to get 10 people together for 32/33 GTST to get the better price.
To organise a group buy is a pain in the arse for who ever organises it.
Some people want one, some are interested but do not confirm if they want one, some want one then pull out when it is time to pay which really stuffs things up as it has recently happened in my last group buy for flywheels
I am only doing this so I can get a cheaper price for my car.
If you want to organise a GTR dump pipe group buy feel free.
Guest darrinspencer
Lawrence
I will be now including GTR as aswell
I will update the first thread soon with prices when I can fit it in between work.
Guest darrinspencer
Lawrence
GTR and GTST are now included in the group buy
Please read the first thread for all the details and prices
Please read the group buy rules aswell.
Thanks
NewB question... what the hell does the waste gate do?? Is it essentially there to create less turbulence as the two exhaust streams meet at a similar velocity?? I'm not too sure.
BTW this will bolt straight on to a stock R33 GTS-t?? If so, is it a DIY jobby?
(In case ur not sure ,I am seriously interested in one of these... just depends on when I can get it etc.)
Cheers.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
