CES Split dump pipes
  • Replies 56
Guest darrinspencer
Has this buy fallen through? Need to know if we can purchase soon!!!
The group buy is still going
Was trying to get 10 people, but that seems to be a bit of a struggle.
If we have 5 people
Darrinspencer 33 phc
WizordOz 33 gtst hpc
Knore 33gtst hpc
Bullant47 33gtst hpc
Croat ????
The price will be a extra few dollars
$550 plain steel (was $530) still a saving of a $100 of normal price
Plus Hpc about $130-150 max. to be confirmed.
So if you guys are happy with this then it will go ahead
I still need Croat to confirm Yes to make up the numbers and what type of pipe you want 33gtst???
If anyone else wants to be in on the group buy please put your hand up now!!
If we get to 10 people, I may be able to get a refund to the first 5 people listed above.
The group buy is now extended to include S13, S14 and S15 SR20 turbo
same prices as 32/33 GTST.
Darrin.
Hi Darrin. I am 100% in on this and don't mind paying a little extra if the number of buyers don't reach 10.
Thanks Darrin
Ken
If we have 5 people
Knore 33gtst hpc
Croat  ????
Darrin.
Guest darrinspencer
Another update
Forget about the extra dollars
We now have 8 pipes sold
Prices will be the same as 10 or more
I will be faxing thru a list to CES of the people who want one
They currently have 4 HPC 33gtst and 2 plain steel in stock
Currently making more
Payment
Payment is to be made directly to CES via C/card or other means
Everyone is to phone them (07 3200 2333) to arrange payment
Mention this group by thru SAU and my name to get discounts (very important)
For people who can pick theirs up, CES will arrange postage at your cost
Please sort this out with them.
The group buy will remain open for other buyers for another month or 2
Thanks
Darrin.
I will contact CES direct to organise mine
Thanks for the hard work darrin :(
I will post before and after dyno figures to give all a idea of the performance gains once fitted
Thanks for the hard work darrin :rofl:
Awesome :D
Ill be calling to pick mine up sometime next week
Got mine fitted on Saturday by Allstar Tuning at Zillmere
Difference on my car between Std. Dump and the CES one was 11 rwk ( 7 % increase )
Torque went up by about 10 %
I am happy with those figures - I have a Electronic Boost Controller so therefore that's an increase due to better flow & less turbulance rather than an increase in realised boost pressure
Will post up the dyno graph tomorrow, Allstar Tuning was kind enough to do the dyno run for nothing so that the results could be posted here :D many thanks to them !!
Will post up the dyno graph tomorrow, Allstar Tuning was kind enough to do the dyno run for nothing so that the results could be posted here :) many thanks to them !!
Great results,
The ces split dump really comes into its own at higher boost too, giving way more flow :)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
