RB26 JE pistons to suit 2.8 stroker crank 77.7mm and 86.5mm bore
Custom made with EN plating and Je perfect skirt.
Valve pockets Suits 1mm over valves biggest lift you can throw at them. 21mm 210” wall 9310 upgraded wrist pins to suit standard sized 121.5mm rods.
I had these made for my build but block had to be rebored to a larger size so sadly I can no longer use them. I spent a-lot of time and money on these pistons.
See photos these are the Heavy duty forging in 2618 material with all the bells and whistles accumulator grooves double force fed pin oilers skirt milling window milling etc.
The En plating was done to the whole piston this helps with heat and also critically in the ring grooves to prevent ring micro welding. The Perfect skirt is JE's propriety coating its a permanent coating that expands and contracts with the bore to prevent piston slap and noise and also friction. you can look these features up.
They have been balanced to a tenth of a gram at my expense. They come with Gas nitrided ring pack's and oil ring rail supports all brand new never used.
The Dome volume is 17.9 cc which based on your Gasket thickness and chamber volume can put you anywhere you like in terms of Comp ratio in my case it was just under 9:1 but this is highly customizable for your build.
In terms of sizing these pistons will work with any 77.7mm build using the normal sized rods.
I did buy an extra set of rings at the time of purchase incase i stuffed one up during gapping so i will throw these in at my expense.
I purchased these through performance wholesale in Brisbane and still have the receipt if you were to make these now it would cost more then double what i have them listed for.
I am super fussy when it comes to building motors so you will see they have been measured and numbered with marker in the photos. Every thing has been handled and stored with the utmost care and diligence.
looking for 2350 ONO
any question please ask.
test is better 0450 428 895
they will be sent via registered post anywhere in Aus free international buyers contact for quote.IMG_2985.thumb.jpeg.1bbb3a78e5a5bb66f1fc8d4b8bc426bb.jpegIMG_2986.thumb.jpeg.2dbdd735ff75b281fa5b7e3abe1474a1.jpegIMG_2984.thumb.jpeg.39295e777930c303a6caa52502326036.jpegIMG_2983.thumb.jpeg.0b91ad1fb9e3c07539401e142f7ac9b0.jpegIMG_2982.thumb.jpeg.692c729850faeb4c25d2a6ce2a28fc46.jpegIMG_2981.thumb.jpeg.6703aa14600c5a0577a89053168343e9.jpegIMG_2980.thumb.jpeg.300494075cb17a94b382ca91957c4c36.jpegIMG_2979.thumb.jpeg.210c334757af3a657a9318ffbd1236a4.jpegIMG_2978.thumb.jpeg.f0ed82c8175c59f1eafbbf533fa18a44.jpegIMG_2977.thumb.jpeg.95d38d4c447eb0137cc5cf376bb41fc6.jpegIMG_2974.thumb.jpeg.f5d6b9bddd1126b912446f966ec82b13.jpegIMG_2973.thumb.jpeg.937d8c4b827499c671b1058ea12b7d9a.jpegIMG_2972.thumb.jpeg.8f24aacdbdce4a4e78e29efd06d2a589.jpegIMG_2971.thumb.jpeg.818cd9bce5ea41d917bd49cae355cd9d.jpegIMG_2970.thumb.jpeg.7e02658e17bd8a95e912f87faf2d08d1.jpegIMG_2968.thumb.jpeg.10f8b3c7d35faafbacc362cacc252d5b.jpegIMG_2967.thumb.jpeg.eb108a7ef56b31ea9a476fa847cfc51d.jpegIMG_2966.thumb.jpeg.14b9d0883f65c6fb6216bce5c0d5e71c.jpegIMG_2965.thumb.jpeg.36d54c23b6d726acffd4d41445e4d75c.jpegIMG_2964.thumb.jpeg.28f52b49f10d72f623755b6a71a541ff.jpegIMG_2963.thumb.jpeg.ea711d1d2a2de677268dd5122fbb7f17.jpegIMG_2962.thumb.jpeg.679025dd0cdcc7fa322b0da4a6664afc.jpegIMG_2961.thumb.jpeg.d368c9cd07e83a0f050e981b160a0cf9.jpegIMG_2960.thumb.jpeg.2291ff95bde08c8c7c89366a952a5227.jpegIMG_2959.thumb.jpeg.14cb4ebda1bb7dae21b276b3576286c3.jpegIMG_2957.thumb.jpeg.1c0c56dd156e8ea89d423242d11371a6.jpegIMG_2961.thumb.jpeg.d368c9cd07e83a0f050e981b160a0cf9.jpegIMG_2956.thumb.jpeg.08b4fbeab1b460f26e94bc3bec8ea1f1.jpegIMG_2955.thumb.jpeg.b5258420207cf68048d17d043785d4a2.jpegIMG_2954.thumb.jpeg.bd86a8065b72689707d7085d5883f62d.jpegIMG_2958.thumb.jpeg.2e244ae808d68a48f16fc0c089591df6.jpeg
https://www.sau.com.au/forums/topic/485484-rb26-stroker-piston-kit-28-777mm/
  • 5 months later...
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
