Hey guys, have searched the internet all over and no one else has posted about this issue I'm having so here it goes. My fuel gauge was reading quarter full when it was actually empty, had a few other issues too and decided to swap to the proper ecu (had a nistune z32 ecu which came in the car) and now not only has the issue remained but it's actually gotten worse now reading half full when the gauge is 0. Anyone got any clue how to fix this?
https://www.sau.com.au/forums/topic/485502-r33-gtst-s15-fuel-gauge-issues/
The ECU has nothing to do with the fuel gauge. Any observations you have made as a result of changing the ECU are meaningless and just coincidence.
There is a variable resistor attached to a float in the fuel tank. The float sits near the bottom on an empty tank and floats up to the top on a full tank, dragging the contact up and down the variable resistor with it. If there is gunk on the resistor it can interfere with conductivity or it can jam the movement of the float (ie so that it hangs up at 25% instead of continuing to fall below that towards the bottom). It can also be a wiring problem caused by hamfisted fuel pump upgrades, or a mechanical problem caused by hamfisted fuel pump upgrades (ie, the hanging of a new fuel pump so that it interferes with the movement of the float). And the list of possible causes probably has a few other things that I can't be bothered to try to invent right now, but will likely have been experienced by others.
Take the sender out and inspect.
Absolute legend, if I have time tonight she'll come out and will sus out if someone along the road has hamfisted anything to do with the pump. If the resistor is all gunked up how would you recommend cleaning it?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
