Hello, is that speed sensor? Why doesn’t it have any cables/2pin but steel cable/rope?
Photos of sensor
R33 gtst auto I swapped it on manual with rp71c#2 gearbox prob rb20det r32.
if I can’t connect current sensor is there any chance that ca/sr speed sensor or rb25automatic sensor will work plug n play?
https://www.sau.com.au/forums/topic/485535-rp71c2-speed-sensor-help-please/
What you are holding that pic is a mechanical cable speedo drive. Not a speed sensor/sender. The R32 gearboxes use cable drive to the speed o head.
No, you cannot put an auto tranny's speed sensor in a manual.
I don't know of a solution for a speed sensor that will work with the R33 dash that will go into that box. The similar boxen from S chassis cars (SR20, etc) use electronic sensors, but I think the drive gears are wrong.
The R32 turbo box will not hold up to the torque of an RB25DET for many years. You will wear out the input shaft bearing. You should probably plan to replace the box with an R33/4 box and then your speed sensor issues will be simpler.
No speedo = no odometer
Also, in case you think that that's a good thing (which it is if you want to keep the mileage artificially low), the ECU needs the speed signal to do things properly. The ECU makes different decisions about things like idle speed etc when it knows that you're moving. The HICAS and various other systems also need to know vehicle speed or they can chuck the sads too.
Edited by GTSBoy
32 minutes ago, WMDC35 said:
R33 non turbo manual has the electronic speedo drive in the small box.
Valid point. That would be true for R34 also.
I should have known that because the 2nd small box I put in my car was an R33 one, and I had to swap my cable drive in for the sender!!
So I’m looking for rb20det sensor or rb25de.
Is this possible that ka24de/sr20 also could work? How much teeth is for small box sensor? 21? Does diameter size vary between these gearboxes?
 https://youtu.be/VPhkpdEH7Lg?si=uGF2tLuAM6Mb5LF2
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
