  • 3 weeks later...
  • 4 weeks later...
11 hours ago, BOLGE said:
thanks for the responses lads, ended up getting a NA Rb25DE NEO head off marketplace for $1200 and porting out the head and putting in supertech valves, pray she works..
Keep us posted with photos too.
I'm wondering if the ported NA head is just as effective as the turbo head (when all things are ported equally).
Wouldn't mind a spare NEO head.
  • Like 1
I'm wondering if the ported NA head is just as effective as the turbo head (when all things are posted equally).
Yeah be interested to know how much meat is in them for porting.
  • 3 months later...
