Hi all have owned my series 1 r33 gtst for 3 years. When I picked it up it wasn't running, but have slowly fixed things during those years. Finally starting to get more time for my r33, currently in the process of sorting rwc and club rego.
I have no real mechanical experience so ive just been learning through youtube and these forums. Just hoping to restore this car and learn alot from everyone in the process
  • Like 5
https://www.sau.com.au/forums/topic/486360-new-r33-owner/
My goals for it atm are to get it registered, respray and some mild power gains eventually...
I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
https://www.sau.com.au/forums/topic/486360-new-r33-owner/#findComment-8002037
  • 2 months later...
Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head
The hose and metal pipe had perished these are the best pics I took of it at the time
20250729_130407(1).thumb.jpg.1c897d9fcd3d476c9632095589433d88.jpg20250729_130325(1).thumb.jpg.8015a694cd8450de0e1b5c226cbe9257.jpg
Edited by jtha7
Image position was wrong
https://www.sau.com.au/forums/topic/486360-new-r33-owner/#findComment-8004246
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
