Hi guys,
I just replaced my pads with blue stuff and flushed fluid. The pedal and brakes feel fantastic but I'm getting very slight pedal stutter under any kind of braking. Not every time, maybe 1 in 10 and not under any heavy braking, mostly occurs as I'm reaching a stop.
It feels like abs engaging but it's so fast, there and gone in under a second and no abs flash on the dash.
Any ideas what could be causing this?
What bedding in procedure did you use?
When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop?
Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop.
I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
Edited by MBS206
The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.
I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
I might do a few more high temp bed ins as described here.
I have a nice quiet 80kph road right near me.
How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
Also, if you didn't machine or replace rotors, it will make it harder to bed the new pads properly. It is something I'll advised to do. And yes, I've done it many times before, and will likely do it again, so no judgement here if you didn't replace or machine the rotors.
2 hours ago, PranK said:
The rotors only have about 5k on them so I didn't worry about the machining.
Murray has the right idea! Or just pretend you're a tow truck driver, they drive around as if it's a race track. Pads will be bedded in in no time! Or you'll arrive at an accident scene quickly...
  • Haha 1
