Gday,
Does anyone have the Nissan FAST software for r32/33 ?
I would appreciate greatly if I could download this from someone on FTP/HTTP.
I realise there is a link for bittorrent somewhere but would like FTP/HTTP if at all possible.
PM or post if possible puh-leese.
Thanks.
https://www.sau.com.au/forums/topic/48797-nissan-fast-software-on-ftphttp/
in the previous threads on the FAST software there is an FTP link. I haven't tested it recently to see if its still up. Its based in russia and max dl speed is about 18kbps.
And FAST, well FAST is the industry system that allows you to check your car's spare part numbers. Also a handy feature is that it contains the ENTIRE list of cars made to the date of issue of that software. Most companies have a version of FAST, and the NISSAN FAST from japan has a lot of interesting info on each Skyline ever sold. All you need is your VIN number and off you go.
Search is your best friend, don't be afraid to bring up a thread that's been dormant for a while.
Gday funkymonkey. Couldn't find a link to a .ru.. all the threads have bittorrents.
Does anyone have a FAST software with database after 1995? That's the car I'm trying to run (1995) to find out what it's specs are. Specifically if it's genuine m spec.
Could someone run one after 1995 for me ? (I don't want to post the details here because it's not my car at the moment..)
Thanks.
Thanks.
all r33 gts25ts are M spec :)
I can also check it if you need
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
