Can ANYONE Get This Best MOTORing Dvd!!!! Please!!!
Guest RedLineGTR
If anyone can get a copy of the dvd in the first post of P2P networks or anything like that. Not the one that i have displayed above it would be great even on a CD-R or something.
Please Feel free to pm me or whatever. Thanks for your time. Rob
I believe the one in the first post is the japanese edition. It's kinda illegal to export it out of Japan, considering BMI owns distribution license in Australia, and therefore only the one in the next post is officially available here in Australia. But hey if you can find one in Ebay, go for it. Good luck.
LOL Like anyone cares about things like that anymore :)
The internet is the source or all illegal things
