so because of the demise of the 15yr rule, the chances of me importing a 32gtst (stock as a rock) have become slim.... ;) But what about SEVS?
Will it work out much cheaper?
On the DOTARS site, it says something about import through a RAW... is this simply applying for import approval through them or does the RAM broker the entire process? Will I be able to import through Jspec and Prestige?
the only thing I understand about SEVS is that you a RAW must carry out the compliance.
thats all i can think of for now....
Cheers
  • Replies 51
so because of the demise of the 15yr rule, the chances of me importing a 32gtst (stock as a rock) have become slim.... :)  But what about SEVS?
Probably not. Compliance for a 15 year old R32 GTST in VIC was about $1200. I'd say the compliance for an R32 under SEVS would be like the R33 compliance costs, so it'd be around the $3500 mark.
Under the 15 year rule, you are allowed to go and get the car from the docks and drive it home (with temp permit), keep it in your backyard, work on it yourself, compliance yourself if you want, and then all you have to do is get the car engineered ($500 of that $1200 you pay to the engineer, $450 side intrusion bars and the rest on bits n pieces like flat mirrors and fuel restrictors etc... all depnding on who does the work for you), then take it to VICroads and get it registered. Easy as.
Under SEVS, the only person allowed to touch that car once it hits aussie shores is a registered workshop (RAW). Technically the car should not touch an australian road until it is complied, but its not something adhered to with diligence :rofl: Basically then the compliance workshop is the only one allowed to touch the car and once the compliance plate is put on the car then you can go pick it up and go get it registered.
You can only import a car under SEVS if you have a RAW lined up to do the work for you once the car gets here.
Either way (under both import methods) the guys at jspec organise a compliance workshop to do the work for you and basically let you know once the work is done, unless you have special requests (some people find their own compliance workshops) etc. The rest of the process is pretty much the same so yeah a broker is still able to handle it for you.
Anyways, the guys at work are much better at explaining all the ins and outs and technicalities than I am, so give em a ring and ask them ;)
foznice: yeah, that is what I would say will happen... as now 1989/early 90 models, can even fetch more than 91/92 models, over in Japan which doesn't make sense. So maybe for the same price, or even less you get a clean 91 or 92 model, SEVS that, and maybe pay $2k more on road. But you get a car which is worth at least $2k more than an earlier car over here, so it would probably even out.
Also as more people (hopefully) import SEVS R32, the compliance costs on them will come down a bit. Not a heap, but a little. R33 SEVS compliance costs have come down from $4500 at the start.
I'm looking to import an R33 GTR and was just about to go ahead when I was warned that the if the car is accident damaged then it would not be complied. The car would have to be re-exported, sold as spares or for racing, it could also be crushed. I dont intend on buying a grade R car, at least grade 4. There is a small chance, however, that an accident repaired car could slip through the system and end up as Grade 4. You may not find out until the car reaches the compliance workshop.
I tried to get assurances from my importer that the car would be inspected before leaving Japan. If your car is found to be accident damaged it could be re-auctioned in Japan with a minimal loss to me. He did not think that was possible so I have sent an email to a UK importer with an office in Japan. Check out their site at www.neweraimports.com
They have a solid word of mouth reputation in UK for sourcing top quality cars (I dont work for them). I have asked if its possible for them to put the car on a ramp and inspect it before it is shipped then produce a concise report and photo's etc.
I will let you know their reply when I get one.
I wonder if anyone else has got any other ideas about how to reduce the risk of importing a lemon?
Thanks
hey guys im still a little confused about all these laws my uncles an importer in jap and he said he would get me a car over without the broker fees and he said around 14,000 for r33 AND 21,000 4 R34 gts-s were talkin here that complied and shipped but without rego.... ok but he estimated the costs of shippin and complience 1g 4 shipping and 4 g 4 complience i want a series 2 aswell a '97 perhaps! is this about correct or not plz help!!
  • 4 months later...
Back to the orginal post :
One FAQ that needs to be in the list is, what kind of modifications away from factory (body or mechanical) are allowed under SEVS.
In a FAQ doc for SEVS http://raws.dotars.gov.au/FAQ2_Nov_2004.pdf (Page 15) is says that :
Q. Can a vehicle fitted with an after market exhaust with aftermarket system be imported under RAWS?
A. Yes. However, the exhaust system fitted to the vehicle when a used import plate is fitted to it must be in accordance with the applicable sample evidence shown on the vehicle inspection certificate submitted for the vehicle.
Does this mean if it passes noise level tests, we can have aftermarket exhausts?
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
