In the latest Drift Battle mag an article mentions that one of the places in Japan which sells the strawberry face upgrades also can do a 34 nose onto a stagea..Pretty sweet.
Copy of email from [email protected]
Its a 6 piece Kit; 275,000JPY, unpainted
Maker has a couple for immediate delivery
To quote Freight for these I would need to know
(1) Airfreight to Airport (ie, Sidney, Brisbane, Melbourne, etc) OR
(2) Delivery To Door by Airfreight (address?) OR
(3) Delivery To Port (slowest and cheapest method)
Importer is responsible for all clearance fees and import tariffs Australia-side
Conversion requires the modification of the Front bumper support Bar; and addition of Skyline GT-R front Grille, Grille badge and Headlights which can be quoted for but are NOT included
Regards
Graham
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
