Hey guyz just looking for sum wheels that would look nice on my car. Found these ones.
Tell me what you think.
Also if u have any suggestions for wheels please post up a pic. Thx :)
Might be the photochop skills but they look shit!
I wanted a set of these but I'm a poor bastard:
