Dont really want to but i think it will be for the best.
Few financial blunders recently have really put me in it at the moment...
Its going to take me at least 3 months to get this car on the road because of them and i dont think i can really have it sitting there for that long costing me money.
Im trying to decide what i should do... sell it whole or sell it in peices. Its got so many aftermarket parts on it that i could probably make more than what i paid for it to this point but it would probably be easier to sell it as a whole for what ive paid for it right now.
Might pull the 18s off it and put them on th soarer and put the soarer wheels on the ceffy and sell it like that :D
This is basically what needs to be done to get it on the road.
-Adjust the suspension to a legal height (has coilovers which are currently wound as low as they go)
-Repair the front bar (its a genuine monkey magic one so no point in wasting it :))
-Repair the rear bar (same as above)
-Put a catback on it
-Side intrution bars
-Remove the rollcage
-Add rear child restraints
-Smaller wheels (enter the soarer wheels :))
-Unleaded filler nozzle thing
And thats about all i can think of.
Would make a nice track car... then you wouldnt have to worry about doing anything to it to road register it but who would honestly buy it for that?
Meh... i need to think about whats to be.
I know once its sorted out i will be on the look out for another car.. more than likely a 4DR R32 or another ceffy.
OH MY GOD - you didn't count on these things when you got it?
Don't do something you'll regret - and shop around for cheaper compliance or do it yourself if thats whats killing you.
Otherwise if you must and do end up selling it in parts I'll buy the cage :D
... BUT NOOOOOO!!!
LOL nah thats not whats the issue... it will just take me about 3 months or so before i can get it on the road... i have other issues which have popped up that are puting me in a tough spot right now financially :D
having a fair idea and the actual cost is a different story... i dont mind posting what i have paid for it to get to my door and i dont mind posting up the invoices which come to 17k.
btw dont mistake this as im desperate to get rid of it for any less than what i paid for it because someones trying to get a bargain... cause im not and nor will i.
more thinking out loud and getting ideas from others.
BLAH!!! What are you thinking crazy man! Just get a dodgy compliance!!! :D
BTW my compliance cost $1200, and I had the intrusion bars rivitted in, not welded in, so they had to be redesigned.
yea cause seriously inark you've got quite the machine there you and meggala have probably the best ceffy's in Australia atm would sad to see it go but didn't you consider all teh costs that you would have to go through to comply it and road register it before the purchase? or did personal things get in the way of funding what you knew you had to do with the car?
a few things came up after purchasing the car :rofl:
cant get em here from anywhere i know of... ive checked everywhere and yet to find one in australia.
im going to have to do some extensive repairs to that front bar and i think i'll only use it for shows and stuff. I need to track down a cheap autech one to stick on for the moment.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
