Well, been told by a mate that's a copper, that EVERYTHING I can do is illegal, from my pod, to future turbo upgrades, to my cars height. Apparently all aftermarket computers are illegal as well. As I said, it's not the cops I'm worried about, it's paying 2k a year for insurance that may be usless. Anyway, cheers, I'll check with Dickson registry and if I can score a full list, I'll let you guys know.
Insurance will insure you with an aftermarket ecu, however they are illegal now unless you get the car emission tested to see if the new ecu complies with emission standards. This comes at a pricey cost (of last time I asked) $4500 and is carried out by Ford.
You can order a set of the Australian Design Rules, as long as you keep to those you should be ok, just tell your insurance company everything you do, and if they dont like it, dont do it.
No offence mate, but cops dotn know whats the dif between whats ilegal and whats not.
best to check through your insurance company. Get them to send you something on what you can and cant have.... well at least ask if they have anything so.
If you want to mod your car and concern about illegal. Then you better get a engineer cert for all of your mods. The engineer will tell you what can do and what can't do. He will write a report to comply your mods with ADR. Better ask before mod. There is a very nice engineer can do the cert. in ACT, John Wilson. I did mine with him... very good bloke.
Cops mightn't know what's legal and what isn't,but ANYTHING changed from the factory is enough for you to get sent "over the pits"-and THAT'S what you should fear most!Be nice to the Police-98% of them are top blokes that are just doing their jobs-I know I've been let off numerous times for not being a smarta**e/admitting that I was doing wrong...
Seriously,you can get sent a defect for simple things like:non-standard fittment tyres,a tissue box on the rear parcel shelf(THAT ticks even me off...),an aftermarket stereo installation,a seat cover...and the list goes on!SO:see an engineer,don't try and slide anything past them OR the Constabulary if you get ''yanked'',and just be happy that we're all driving nicer cars than most...
I've seen some pretty full-on rides that have been 100% certified.My l'il beastie is already well engineered;when it's fully done,it'll be a MUCH harder hitter,AND it'll be legal!!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
