I only recently got my r31 1990 4 door skyline
the problem is that the drivers side seat is broken and lean's to one side, i have a chance of pulling out some seats from a mates wrecked pintara 1987 model. Will they fit ?
and later on down the track we want to buy either R32 GTS seats or R31 gts seats, same question, will these fit ?
And any other stock skyline seats that would just bolt up.
thank you for your advice
https://www.sau.com.au/forums/topic/50326-what-front-seats-fit-into-r31-4-door/
Pintara seats should fit no problems.
No import seats fit. That includes import R31 onwards, as they have a different floorpan design to the aussie ones unfortunately.
I tried with R33 seats myself, not much chance - and its not possible to simply swap the rails over between the two. You need to get something welded up to get them in I am pretty sure.
Stock seats from all R31's will bolt in no drama.
The Aus spec GTS seats will fit. (If you can find any)
I know of at least one aus R31 that has GTR seats in it, but there was a lot of modification made to the seat rails to get them to fit, and the passenger seat sits fairly high.
If ur looking for GTS seats... i can help u out with the complete interior...that is the 2 front seats and the rear seat...also with the door trims...all is original GTS items... Also have as well the complete GTS bodykit...Which include GTS front bar...rear bar and side skirts..all geniuine.let me know if intrested
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
